Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: ford 9n has no spark!!! 6 volt system
Royse
07-05-2013 16:44:55
Sounds like your points are opening and closing correctly.
Is the coil secondary tab making good contact with the cap?
If not you can clean it and bend it down a bit to see if that helps.
If it is, you may have a bad coil. I wouldn't jump on that just yet,
but its a possibility.
Are there any noticeable cracks in the exterior of the coil?
chuck0794
07-07-2013 20:45:46
 Re: ford 9n has no spark!!! 6 volt system in reply to Royse, 07-05-2013 16:44:55
Coil is brand new. I tried the old one 2 with the same results. I'm going to take it apart again to look @ the gap to make sure. Im getting pretty good @ taking it apart!!! Lol
chuck0794
07-06-2013 12:10:26
Bruce (VA)
07-06-2013 12:42:08
 Re: ford 9n has no spark!!! 6 volt system in reply to chuck0794, 07-06-2013 12:10:26
" I'm going to take it apart again to look @ the
gap"
Well, that's one of at least ten possible causes for a no spark situation.
You might want to check more than one thing at a time while you have the distributor off of the tractor....... ;)
chuck0794
07-07-2013 09:06:00
 Re: ford 9n has no spark!!! 6 volt system in reply to Bruce (VA), 07-06-2013 12:42:08
Bruce.
I tested it out how u mentioned in your steps. One question I have is the red light is disconnected. It was like that when I brought it home. Is this a problem???
Copyright © 1997-2015 Yesterday's Tractor Co.
