Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: generator
roadteck
07-05-2013 13:25:32
looks like cutout has generator wire run to bottom
connection and top connection wire run to amp guage is that correct ?
roadteck
07-05-2013 14:38:16
 Re: generator in reply to roadteck, 07-05-2013 13:25:32
tried jumper wire same thing is it possible amp guage is backwards ?
Royse
07-06-2013 20:39:48
 Re: generator in reply to roadteck, 07-05-2013 14:38:16
I don't think so. When you turn on the lights, the gauge should
show discharge because they are drawing on the battery.
Just as you say it does.
Do you have an analog volt meter to test with?
A cheap one will work as long as its not digital.
Double check the ground on your generator also.
36 coupe
07-06-2013 15:03:49
Turn on the lites.Ammeter should move to discharge or minus side.Battery could be connected wrong if it moves positive.
