TractorLinks.com
Show Parts for Model:
Re: pto shaft
Bruce (VA)
07-05-2013 10:32:35
It depends on where it's broken. If you can drain the fluid, remove the 4 bolts & pull it out, then it's an easy job.
If you can't pill it out, then the job just became a PITA because you need to cut the shaft.
Just replace the entire shaft & bearings as a unit; about $120 as I recall.
cory eneks
07-05-2013 12:38:30
 Re: pto shaft in reply to Bruce (VA), 07-05-2013 10:32:35
first what is a PITA job
JCinKY
07-05-2013 12:40:36
 Re: pto shaft in reply to cory eneks, 07-05-2013 12:38:30
Pain in the a$$.
If you gotta cut the shaft, you'll understand. :lol:
cory eneks
07-05-2013 12:50:29
 Re: pto shaft in reply to JCinKY, 07-05-2013 12:40:36
so basicly the shaft and the bearings should all come out together,,,and the kit should go back in????????
JCinKY
07-05-2013 12:56:28
 Re: pto shaft in reply to cory eneks, 07-05-2013 12:50:29
Yup. Drain the oil, 4 bolts, yank the old one out. Everything comes out together. Shaft, seal, bearing.
Dell (WA)
07-05-2013 12:57:45
Cory.......sometimes you can park yer tractor nose deep in a ditch so you don't haffta drain 5-gals of hydro-tranny oil. ...otherwize... ittza oil in the armpits job draining all 3"-drains. As said, replace yer ENTIRE PTO shaft with its built-in bearings and seals. Recommend the modern 1-3/8" PTO shaft. .......clean pits Dell
