Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Not getting gas to motor 8n
Royse
06-30-2013 19:01:14
In your first post you said it was rebuilt, did you take it apart again?
If not, I would suggest taking it apart and running a small gauge
electrical wire through each and every passage.
Carb cleaner and compressed air are good, but not always good
enough to actually get it to run right.
These pics from forum members JMOR and GB in MT may help.
36 coupe
07-01-2013 02:51:02
 Re: Not getting gas to motor 8n in reply to Royse, 06-30-2013 19:01:14
Note the passage from the bowl to the drain plug.It can be plugged with rust so taking the plug out and seeing no gas flow might make you think the bowl is empty.The main jet can plug so check that first.
bosco1
07-02-2013 19:36:09
 Re: Not getting gas to motor 8n in reply to 36 coupe, 07-01-2013 02:51:02
first thanks to everyone that helped. She runs !! there was a orefice under the main needle plugged.the tractor still does not like to start with starter. But if you pull 5 feet starts right up runs and idles excellent!! guitar strings worked excellent for cleaning orifice out!
bosco1
07-02-2013 18:37:46
