Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Low oil pressure Jubilee
notjustair
06-30-2013 08:59:19
If it has good pressure it may be ok. The biggest issue is that the bearings may have heated up and scored. That would likely show right away, but if they are roughed up due to friction they will wear pretty quickly. I wouldn't be too surprised if it lost a good bit of oil pressure in the next 50 hours. If that were the case you would get that rod knock.
I've seen bearings that ran low on oil ruin a crank pretty good, too. I would say if the pressure drops plan on doing the crank when you open it up. I'm of the mind that the oil light never comes on (or pressure drops) without some residual damage.
I guess if one ran the battery low and then it charged full steam for a while the VR might heat up enough to cause the problems you mentioned. Indirectly it could cause it, but directly there is no link between the two.
This goes without saying, but don't let this guy borrow anything of yours again!!! It wasn't your new car - it was a decades old tractor that needs TLC.
William Fissell
06-30-2013 09:58:35
 Re: Low oil pressure Jubilee in reply to notjustair, 06-30-2013 08:59:19
Actually I like the guy, and he is doing some good things (small scale organic farming) and I'll take my chances. its not like I never screwed up and was never forgiven for a mistake.
I kinda agree with you- I'm a little worried the drivetrain has been altered by this.
36 coupe
06-30-2013 13:57:09
 Re: Low oil pressure Jubilee in reply to William Fissell, 06-30-2013 09:58:35
If he cant check oil he shouldnt be using your tractor.
Texas!
06-30-2013 11:22:59
I personally won't loan my tractors out. There's just too big of a chance that they will come back broken and then hard feelings will exist. If the loanee agrees in advance to fix anything he breaks it might change my mind but it's still dangerous.
soundguy
07-01-2013 07:50:57
 Re: Low oil pressure Jubilee in reply to Texas!, 06-30-2013 11:22:59
same way i feel.
