8n points...
dave404
I know the gap set for a sidemount is .25 , is this for new points only ? mine seems to start and run at .19 better. of course the points are not new. 52 side mount 8n
(quoted from post at 17:55:57 06/29/13) I know the gap set for a sidemount is .25 , is this for new points only ? mine seems to start and run at .19 better. of course the points are not new. 52 side mount 8n
hatever works for you......I was never able to set any to a quarter of an inch!
Set the gap at .025 and then set the timing.
See if that gets you the same thing in performance as setting them at .019. Which will burn them up.
75 Tips
