This is for all you "know it all" people, let"s really see if you know it all. Purchased an overhauled bare block from Iowa. New oil pump kit, new governor. Fired up like it was supposed to, no oil pressure.The oil pump was pre-lubed and so was the oil pressure relief hole, forgot to mention, new oil pressure relief pin & spring, new oil P/U tube. Took the oil line loose from the guage, started the tractor, no pressure or oil. Removed the line from the governor, same issue,nada.I blew air in both lines & the oil filter cup was singing with air. I also removed the oil pressure relief valve & stretched the spring, no help.
Alright, let"s hear it, what"s the deal?
