TractorLinks.com
Show Parts for Model:
Re: Fuel tank issues
TheOldHokie
06-29-2013 13:43:29
No - it wouldn't even start into the hole. Do as the seller says - the straight thread that is in the tank is designed to seal with a properly sized taper pipe thread. If you bought the sediment bowl fitting he referenced in the gas tank listing (item number 221081754982) it should work properly. Put a little pipe thread sealant or a wrap of teflon tape on the male thread before you install it. It should go in almost two turns until it is hand tight. Then give it another turn with a wrench until it is properly oriented. Done.
TOH
