Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Fuel tank issues
Dave Wave
06-29-2013 11:48:12
Assuming the tank is threaded 3/8 -18 and the shutoff valve is 3/8 NPT - would that combination work?
06-29-2013 13:43:29
 Re: Fuel tank issues in reply to Dave Wave, 06-29-2013 11:48:12
No - it wouldn't even start into the hole. Do as the seller says - the straight thread that is in the tank is designed to seal with a properly sized taper pipe thread. If you bought the sediment bowl fitting he referenced in the gas tank listing (item number 221081754982) it should work properly. Put a little pipe thread sealant or a wrap of teflon tape on the male thread before you install it. It should go in almost two turns until it is hand tight. Then give it another turn with a wrench until it is properly oriented. Done.
