8N thermostat
Billy Shafer
Where is the thermostat on an 8N. With front mounted distributor.Don't see any thing like a normal thermostat mount.
Billie........would you believe the thermostat for the flathead 8N engine is in the upper rubber radiator hoze??? Pointy end facing the radiator. just stuff it in. Simple, eh? ......... Dell
Easiest way to find it is start squeezing on the hose. If you find a hard spot its got one in it. No hard spot, not t-stat.
to supplement what everyone else said after replacement put a wire tie or radiator hose clamp around hose where t-stat is located to keep it from wandering up and down the hose.
Was at the local aerodrome. Met CARL. Retired Motorola engineer. No trade, NO skills, just part of the electrmechanial boys. Now retire.
Welcome CARL on board. He understands "kithen aprons" fer warming up coffee in Radar Ranges.
I volunteered to be HIs FI (flight instructor" for night times., here at KWO5.
Take care. John,PA
Hope YOUR legs are a legg'N. John,PA
PS: I like 'dem crab cakes in BALTIMORE HARBOR.
(quoted from post at 12:19:43 06/29/13) to supplement what everyone else said after replacement put a wire tie or radiator hose clamp around hose where t-stat is located to keep it from wandering up and down the hose.
