Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: More on front mount points
06-27-2013 16:26:52
did they look molded plastic or laminated??
the laminated picture I posted came in this box:
This post was edited by JMOR at 16:28:55 06/27/13.
36 coupe
06-28-2013 04:17:21
 Re: More on front mount points in reply to JMOR, 06-27-2013 16:26:52
The laminated material is called Micarta.Tough material used as insulation and makes good knife handles.May have spelled it wrong,first time Ive typed the word.I have found many Ford v8 distributors with a broken left point spring.That shorts the points.I have two under the bench with that problem now.The photos show that points have 2 metals welded together.I think tungsten welded to steel.Hard to rivet tungsten.Good points are too hard to file.
06-27-2013 17:22:23
Does this picture show you what you are interested in? These are the Blue Streak points in the Tisco package.
36 coupe
06-28-2013 04:00:34
 Re: More on front mount points in reply to HCooke, 06-27-2013 17:22:23
No brass bushing,doubt they are Blue Streak points.Blue Streak points had a red felt lube wick when I was a pup.
06-27-2013 17:59:18
They look laminated at least.
I noticed that there is a lot of difference between the spring
shapes on the different sets of points as well.
