Guy in WA State
New User
I have a 1951 Ford 8n with side distributor that I inherited a couple years ago.
It has been having a problem of stalling almost every time I put it in gear and let off the clutch.
It also would not start without a quick shot of starting fluid each time.
I decided to start troubleshooting by cleaning the fuel system and replacing points/condenser.
I cleaned out the tank, which looks very good inside. I cleaned the inside tank filter (it looked good). I replaced the filter (it looked good) and cork seal on the fuel shutoff valve assembly. I pulled and checked the filter in the fuel inlet to the carb (it looked good).
I pulled the air intake tube running from the carb and made sure it was clear.
I assembled the fuel lines back to the carb. I took out the brass plug on the bottom and let fuel run through. Everything looked clean. I timed the fuel over the course of a minute while it ran into a container and collected about 11 oz, I think. I then replaced the plug.
So, now when I open the fuel valve at the tank, after a couple of seconds, fuel runs out the air intake of the carb. I knocked on the carb a little bit but nothing seemed to change.
What would you suggest for my next step?
Do you think that a carb rebuild is the best option or should I be thinking about some type of cleaning while it is still attached to the tractor?
