TractorLinks.com
Show Parts for Model:
Re: jump start 6v fom 12v
Jubilee85(VA)
06-26-2013 18:42:02
never go battery to battery! make sure in neutral - lock clutch down if possible - go from 12 volt source - connect the correct leads, - To - and then + on 12 volt battery to the 6 volt starter! It is going to spin even if the key is off, so make sure the key is in the run position. Even if one is positive ground and the other negative, make the last connection to the starter of the 6 volt tractor. SO if the tractor is positive GROUND, the last connection will be a - lead to the starter.....
hope I did not confuse the he!! out of you, and if I missed something - some one will point it out!
JCinKY
06-26-2013 19:07:16
 Re: jump start 6v fom 12v in reply to Jubilee85(VA), 06-26-2013 18:42:02
Don't even worry about tractor battery polarity.
After its in neutral and key on, hook either cable to starter hot and ground that sucker to the chassis! If it makes you feel better + to starter hot and - to frame.
Starter don't know polarity, it will turn in the correct direction.
