Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Temperature Gauge
36 coupe
06-26-2013 04:58:57
Cast iron is never easy to tap.If you have ever looked at cracked heads or blocks you will know thin the casting is.If I could measure the thickness of the cast in the area to be tapped and found it thick enough I would tap it.You have to have an adapter for temp bulbs installed in block.The temp bulb needs a shoulder to be water tight.Cast iron can have some very hard spots in it.
06-26-2013 05:11:52
 Re: Temperature Gauge in reply to 36 coupe, 06-26-2013 04:58:57
i've been pretty lucky. have never had an issue cutting, drilling, or tapping threads in cast iron. if there is thin webbing.. I can see an issue with threading.. but that can be mitigated with a lil brass. besides. the new style heas have a boss for a temp bulb. i'd think the ford engineers probably designed it with sufficient metal for that to happen..
36 coupe
06-26-2013 15:54:12
 Re: Temperature Gauge in reply to soundguy, 06-26-2013 05:11:52
The 9n engines were used in light trucks and had heads that were different from tractor heads. the trucks had a temperature gauge.Ford did not use electric temperature gauges until 1940.
06-27-2013 05:50:03
 Re: Temperature Gauge in reply to 36 coupe, 06-26-2013 15:54:12
all replacement heads will have the boss as well as the later industrial heads too.
