TractorLinks.com
Show Parts for Model:
Re: Temperature Gauge
soundguy
06-26-2013 04:42:00
the machinist shouldn't be doing too much guessing. witht he head in hand.. he should precisely know if it can be tapped. if it can't. he can always plug it.
36 coupe
06-26-2013 04:58:57
 Re: Temperature Gauge in reply to soundguy, 06-26-2013 04:42:00
Cast iron is never easy to tap.If you have ever looked at cracked heads or blocks you will know thin the casting is.If I could measure the thickness of the cast in the area to be tapped and found it thick enough I would tap it.You have to have an adapter for temp bulbs installed in block.The temp bulb needs a shoulder to be water tight.Cast iron can have some very hard spots in it.
soundguy
06-26-2013 05:11:52
 Re: Temperature Gauge in reply to 36 coupe, 06-26-2013 04:58:57
i've been pretty lucky. have never had an issue cutting, drilling, or tapping threads in cast iron. if there is thin webbing.. I can see an issue with threading.. but that can be mitigated with a lil brass. besides. the new style heas have a boss for a temp bulb. i'd think the ford engineers probably designed it with sufficient metal for that to happen..
36 coupe
06-26-2013 15:54:12
 Re: Temperature Gauge in reply to soundguy, 06-26-2013 05:11:52
The 9n engines were used in light trucks and had heads that were different from tractor heads. the trucks had a temperature gauge.Ford did not use electric temperature gauges until 1940.
soundguy
06-27-2013 05:50:03
 Re: Temperature Gauge in reply to 36 coupe, 06-26-2013 15:54:12
all replacement heads will have the boss as well as the later industrial heads too.
