IGNITION RESISTOR BURNING UP
Falcon
New User
I recently installed an electronic ignition assembly on my 9N with front mount distributor. I also replaced cap, rotor button, plug wires & plugs at same time. It ran great for a couple of weeks (probably 7 to 8 hours total run time) then the ignition resistor went out, it was extremely hot to the touch. I installed a new one and the tractor cranked up and ran for about 5 minutes, then quit. The new resistor was also extremely hot and when I tested it it showed no resistance. I decided to check the coil and it shows no resistance between top post and spring on bottom. The tractor was converted to 12V before I got it so I don"t know if the coil is 6V or 12V. Shouldn"t there be some resistance between these two points on the coil? If the coil is bad and I need a new one I will probably get the 12V coil for it. If I do install a 12V coil do I still need a resistor in line? I checked behind the dash and did not see any other resistors in the wiring.
wow.. this post is a mess.
1, I'd consult twith the maker of your high dollar e-ignition unit and find out what they reccomend.. since doing the wrong thing can burn up that module.
What do you mean by "shows no resistance"? Ordinarily, in the electrical/electronics world, such a statement means that the resistance is ZERO Ohms, i.e., a really good heavy copper wire of short length. What does it mean to you?
Both the coil primary & the resistor will be so near to ZERO, that many persons do no recognize what they are reading or the sorry instrument/techniques make it near impossible for them to obtain an accurate measurement. Your EI mfgr. specifies a minimum combined coil + resistor value of 3 Ohms. The resistor can show a red color & ignite a piece of paper when touched, so keep in mind that it is normal for it to be far too hot to touch, unless you enjoy pain & the smell of burning flesh.
I have a quality digital ohm meter. When I said zero resistance I meant the same as touching the two leads of the meter together. 0 ohms.
(quoted from post at 12:03:59 06/24/13) I have a quality digital ohm meter. When I said zero resistance I meant the same as touching the two leads of the meter together. 0 ohms.
ot the way it should be. The coils are generally around 0.5 to 1.5 Ohms if 6v and about 2.5 Ohms if 12v.
The standard Ford 12250 resistor is ~0.4 Ohm cold and ~1.7 Ohms when red hot.
Thanks for the info. I assume then that my coil is bad if it is reading 0.00 ohms. I guess I will be replacing with a 12V coil. Do I still need any type of resistor with a 12V coil?
(quoted from post at 12:45:42 06/24/13) Thanks for the info. I assume then that my coil is bad if it is reading 0.00 ohms. I guess I will be replacing with a 12V coil. Do I still need any type of resistor with a 12V coil?
es. Remember I said that Pertronix specifies 3 Ohm minimum for coil + resistor combination? Well, 3 - 2.5 = 0.5, so......use the Ford 12250 resistor.
(quoted from post at 13:29:22 06/24/13) Thanks for your help Jmor, I just ordered the 2 parts. I'll let you know how it works out.
ppreciate feedback. Might try Ohmmeter on the new parts when they arrive, too.
