Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8n ver.600
TheOldHokie
06-24-2013 15:02:10
stansab said: (quoted from post at 16:58:47 06/24/13) how is a ford 600 differ from 8n
Larger and heavier with an over head 134 CID engine (more HP), live hydraulics standard, optional PS, optional live PTO, and better gearing options.
TOH
This post was edited by TheOldHokie at 15:05:40 06/24/13 2 times.
stansab
06-24-2013 15:12:06
 Re: 8n ver.600 in reply to TheOldHokie, 06-24-2013 15:02:10
thanks for the reply how would you compair naa to 600
soundguy
06-25-2013 07:05:37
 Re: 8n ver.600 in reply to stansab, 06-24-2013 15:12:06
an naa would be like a primitive 640.. difference would be inferior rear hub design.. and a stepchild nearly unsupported hyd cover arangement.
a naa will do the same work as a 640
looking at the entire 600 series. same as others said. options you might find are power steering and live pto, better trans gearing..e tc.
TheOldHokie
06-24-2013 15:49:37
The 600 was available with many more useful options - most notably transmissions. The NAA was basically a one size fits all interim model that lasted a scant 3 years.
TOH
NoNewParts
06-25-2013 05:31:23
 Re: 8n ver.600 in reply to TheOldHokie, 06-24-2013 15:49:37
TheOldHokie said: (quoted from post at 19:49:37 06/24/13)
stansab said: (quoted from post at 18:12:06 06/24/13) thanks for the reply how would you compair naa to 600
TOH
like TOH said, more tranny options, live pto option
also a more 'standard' remote hook-up plate
original NAA's also had a vane pump, which is usually changed to a piston pump- new external lines needed for that.
biggest flaw with my favorite NAA's is they have the
8N style rear axle with the eventual loose hubs issue.
And pretty much everything about the NAA rear lift is 'NAA only'
hold out for a hundred series
like the other poster said, almost the same price
don't rule out the 'blue' ones either
some decent deals out there if you look
then you have dual range, ps, etc,etc
This post was edited by NoNewParts at 05:40:43 06/25/13 2 times.
