Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: Ford 8n runs for five minutes then dies. Will not restar...
06-24-2013 12:30:26
6 or 12 volt?? Front or side mount distributor?? Can make a difference as to what is wrong. I would try a hot wire from the battery to the coil. If it runs then you have a problem from the distributor back if it still does the same thing could be fuel problem and to check that pull the drain plug from the bottom of the carb and let it flow for a few minutes. Catch the gas to make sure it is not full of water or dirt etc. Also check your spark when it dies should have a good blue white spark that jumps a 1/4 inch gap
