TractorLinks.com
Show Parts for Model:
Re: IGNITION RESISTOR BURNING UP
Falcon
06-24-2013 09:45:42
Thanks for the info. I assume then that my coil is bad if it is reading 0.00 ohms. I guess I will be replacing with a 12V coil. Do I still need any type of resistor with a 12V coil?
JMOR
06-24-2013 09:52:07
 Re: IGNITION RESISTOR BURNING UP in reply to Falcon, 06-24-2013 09:45:42
Quoting Removed, click Modern View to seeYes. Remember I said that Pertronix specifies 3 Ohm minimum for coil + resistor combination? Well, 3 - 2.5 = 0.5, so......use the Ford 12250 resistor.
Falcon
06-24-2013 10:29:22
 Re: IGNITION RESISTOR BURNING UP in reply to JMOR, 06-24-2013 09:52:07
Thanks for your help Jmor, I just ordered the 2 parts. I'll let you know how it works out.
JMOR
06-24-2013 10:37:06
 Re: IGNITION RESISTOR BURNING UP in reply to Falcon, 06-24-2013 10:29:22
Quoting Removed, click Modern View to seeAppreciate feedback. Might try Ohmmeter on the new parts when they arrive, too.
