TractorLinks.com
Show Parts for Model:
Re: IGNITION RESISTOR BURNING UP
JMOR
06-24-2013 09:11:18
Quoting Removed, click Modern View to seeNot the way it should be. The coils are generally around 0.5 to 1.5 Ohms if 6v and about 2.5 Ohms if 12v.
The standard Ford 12250 resistor is ~0.4 Ohm cold and ~1.7 Ohms when red hot.
Falcon
06-24-2013 09:45:42
 Re: IGNITION RESISTOR BURNING UP in reply to JMOR, 06-24-2013 09:11:18
Thanks for the info. I assume then that my coil is bad if it is reading 0.00 ohms. I guess I will be replacing with a 12V coil. Do I still need any type of resistor with a 12V coil?
JMOR
06-24-2013 09:52:07
 Re: IGNITION RESISTOR BURNING UP in reply to Falcon, 06-24-2013 09:45:42
Quoting Removed, click Modern View to seeYes. Remember I said that Pertronix specifies 3 Ohm minimum for coil + resistor combination? Well, 3 - 2.5 = 0.5, so......use the Ford 12250 resistor.
Falcon
06-24-2013 10:29:22
 Re: IGNITION RESISTOR BURNING UP in reply to JMOR, 06-24-2013 09:52:07
Thanks for your help Jmor, I just ordered the 2 parts. I'll let you know how it works out.
JMOR
06-24-2013 10:37:06
 Re: IGNITION RESISTOR BURNING UP in reply to Falcon, 06-24-2013 10:29:22
Quoting Removed, click Modern View to seeAppreciate feedback. Might try Ohmmeter on the new parts when they arrive, too.
