TractorLinks.com
Show Parts for Model:
Re: 2n Quadrant adjustment
Jason S.
06-21-2013 13:13:47
You have to adjust the draft control spring first and then adjust the quadrant. When you have an implement lifted you should just barely be able to turn the spring by hand. When you have the draft control spring adjusted properly then measure down 2 3/4" from the top of the quadrant. With the forward edge of the control lever at this spot slowly move the quadrant forward. When the implement starts to drop tighten the bolts on the quadrant. Then check it again because sometimes it moves when you tighten it down and you have to start over.
