Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: no spark
Bruce (VA)
06-21-2013 11:17:15
" the distributor cap at where the plugs plug in""
I think he's talking about the end of the rotor & the cap nipples......
But maybe not.
Rick Rhea
06-21-2013 12:20:34
 Re: no spark in reply to Bruce (VA), 06-21-2013 11:17:15
I think that I am talking about the end of rotor and the inside of cap (maybe called cap nipples) it is oppisite where the plug wires plug in. I thought that the rotor was supposed to actually touch the cap at each plug spot but it appears to be about 1/8 or so from touching?
06-21-2013 12:33:31
 Re: no spark in reply to Rick Rhea, 06-21-2013 12:20:34
If the rotor touches the cap while spinning at 1500 rpm, your gonna do lots of damage to the cap and button...probably more.
The gap you are talking about is supposed to be there. Spark will jump from the button tip to the cap contact as it rotates past, thus sending spark to your plugs.
Nipples are where your plugs connect on the outside of the cap. And yes they are "opposite" (inside vs. outside of cap) of each contact inside the cap.
Do as Dell said and make sure the spring tab on top of the button actually touches the coil contact on the inside center of the cap.
Man...this is getting confusing :lol: :lol:
Rick Rhea
06-21-2013 13:23:59
 Re: no spark in reply to JCinKY, 06-21-2013 12:33:31
Thanks for the reply. This thing is driving me nuts. I will check the spring tab on the rotor.
What about the 12 volts at the top of the coil and then with turning it over the voltage drops to 8.5 volts?
Bruce (VA)
06-21-2013 13:27:01
 Re: no spark in reply to Rick Rhea, 06-21-2013 13:23:59
" What about the 12 volts at the top of the coil and then with turning it over the voltage drops to 8.5 volts? "
I've already answered that question once.
Are you getting my posts or did you overlook the answer?
