TractorLinks.com
Show Parts for Model:
Re: 2n Quadrant adjustment
Glenn D
06-21-2013 10:52:08
That makes sense. Its just that all my adjustment seems to be at the bottom
J.Stones
06-21-2013 11:11:04
 Re: 2n Quadrant adjustment in reply to Glenn D, 06-21-2013 10:52:08
Quoting Removed, click Modern View to seeI believe that if you slide the 4 bolt quadrant adjustment forward, that the control arm position for lift will be closer to top of travel.
Glenn D
06-21-2013 12:14:03
 Re: 2n Quadrant adjustment in reply to J.Stones, 06-21-2013 11:11:04
Hrm well I used a small pry bar and slid it all the way forward and there was no change in the position of the arm.
J.Stones
06-21-2013 12:26:38
 Re: 2n Quadrant adjustment in reply to Glenn D, 06-21-2013 12:14:03
Quoting Removed, click Modern View to seeAll the way fwd to all the way back should make a difference, very strange & a little difficult to comprehend, since that movement is doing the same thing to top of control fork that moving lever which rotates shaft with eccentric & that too moves top of control fork????
Glenn D
06-21-2013 11:16:17
I will give it another try. Not realizing it could be slid forward I took the instructions to mean rotate
