Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2n Quadrant adjustment
JMOR
06-21-2013 10:43:06
Quoting Removed, click Modern View to seeRaise to lower or lower to raise is a very narrow range of movement, since that tractor does not have position control. Lower should begin as lever is moved downward from top by about 2 3/4 inch and very little more should lower fully & by the time you reach about 1 inch from top, lift should be full up. What is all that other available travel lower in quadrant for? To give you control when a plow is compressing the draft control spring & moving the draft control plunger inward. Without Position control as with 8N, you have basically an on/off (lift/drop) control.....not much "in between".
Glenn D
06-21-2013 10:52:08
 Re: 2n Quadrant adjustment in reply to JMOR, 06-21-2013 10:43:06
That makes sense. Its just that all my adjustment seems to be at the bottom
J.Stones
06-21-2013 11:11:04
 Re: 2n Quadrant adjustment in reply to Glenn D, 06-21-2013 10:52:08
Quoting Removed, click Modern View to seeI believe that if you slide the 4 bolt quadrant adjustment forward, that the control arm position for lift will be closer to top of travel.
Glenn D
06-21-2013 12:14:03
 Re: 2n Quadrant adjustment in reply to J.Stones, 06-21-2013 11:11:04
Hrm well I used a small pry bar and slid it all the way forward and there was no change in the position of the arm.
J.Stones
06-21-2013 12:26:38
 Re: 2n Quadrant adjustment in reply to Glenn D, 06-21-2013 12:14:03
Quoting Removed, click Modern View to seeAll the way fwd to all the way back should make a difference, very strange & a little difficult to comprehend, since that movement is doing the same thing to top of control fork that moving lever which rotates shaft with eccentric & that too moves top of control fork????
Glenn D
06-21-2013 11:16:17
I will give it another try. Not realizing it could be slid forward I took the instructions to mean rotate
Copyright © 1997-2015 Yesterday's Tractor Co.
