Mike Rakow
...you install it? I am considering replacing the distributor with a complete unit (dist/cap/points/gaskets). 9N front mount, 12 V round can conversion. It looks like these units are fully assembled and ready to install. For those that have purchased this item, do you know if they are set up, timed and the points gapped properly?
I know with the distributor in your hand or on the workbench, these things are easy to check....and I would double check before installing anyway, but what I am asking is does the factory set these up?
Thanks!
Mike
Thanks!
Mike
