TractorLinks.com
Order Ford 8N Parts Online
Re: 51 Ford 8N
Royse
06-20-2013 19:28:48
Welcome to the forum!
Are you sure it's a 1951?
Does it have a front mount or side mount distributor?
It does make a big difference in what could be wrong.
In either case, when it quits, does it still have good spark
at the plugs? Should be a good blue/white color when checked.
If it has good spark, you could check fuel flow from the bottom
of the carb drain. It should flow steady, not dribble out.
Both need to be checked right at the moment of stall.
It would also help to know if it has been converted to 12 volts,
has an Electronic Ignition, etc, but basic troubleshooting is still
spark-fuel-air at the right times.
Let us know! :)
Timmy S
06-20-2013 19:50:28
 Re: 51 Ford 8N in reply to Royse, 06-20-2013 19:28:48
Thanks Royse
Yes, according to the reference with the serial number it is a 51 side mount distributor. I did not check the plugs but did the fuel flow. That is what I first thought the problem was, but has good fuel flow. It has not been converted. It is a six volt still orignal. I want to keep it all orignial looking.
