TractorLinks.com
Show Parts for Model:
Re: Plow question
Royse
06-20-2013 19:19:13
From the front, I was meaning the right one.
You could unbolt it where circled, put it in the barn and
bolt it back on when needed to plow.
This would leave you only the one bottom and let you
manuever closer to or farther away from your rows.
It's just a thought.
A hiller would work better, but I don't have one of those! :)
gwstang
06-21-2013 17:02:08
 Re: Plow question in reply to Royse, 06-20-2013 19:19:13
Update! I removed the plow you had circled and moved the one (on the outside) to the inward about 4 inches or so. I was then able to put the right side wheels on the other side of the 'tater plants and the plow on the left of the plants and it worked beautifully. I could not be any happier with the results. Thanks to every one for the help! This is much better than a shovel.
gwstang
06-20-2013 19:47:00
I'm going to make a hiller next year. I have seen the parts to make one on agrisupply in the small catalog they send out every month or so.
gwstang
06-20-2013 19:45:06
AhhSooo. Thanks for the clarification. I'll also give the going faster a try as it will probably go better with just one attached. I'll pull it off in the morning and give it a go.
