TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8N Cracked Block
LMJ
06-20-2013 16:22:53
Cooling system is clean. Without having to do any testing it is obvious that it is building pressure. I don't see any exterior leaks. I had the head leveled that took 8 thousands and checked for cracks so it shouldn't be overheating.
soundguy
06-20-2013 16:34:52
 Re: Ford 8N Cracked Block in reply to LMJ, 06-20-2013 16:22:53
a cooling system pressure test is not for seeing if there is pressure building inthe cooling system.
you not into testing? no problem.
good luck with the issue.
LMJ
06-20-2013 16:54:30
 Re: Ford 8N Cracked Block in reply to soundguy, 06-20-2013 16:34:52
I DID NOT SAY I wouldn't do testing I just am open for suggestions. I just thought someone had run into a problem like this and had an idea!!
JMOR
06-20-2013 17:01:52
 Re: Ford 8N Cracked Block in reply to LMJ, 06-20-2013 16:54:30
Quoting Removed, click Modern View to seeI have & the radiator was fine, BUT the block was so full of rust that water could hardly, if at all, get between the cylinders!
