Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Back to the 2N and mower
06-19-2013 12:28:34
the first thing i would do is shorten top chain to rear of mower..this will allow the rear of mower to lift .it dosen't need to be level when raised..this should stop drive shaft from hitting..also i would shorten short chains to sides of pto..this will limit the mower from raising too high..i have mine set so driveshaft just misses hitting front of mower..hth...phil
Glenn D
06-19-2013 12:46:57
 Re: Back to the 2N and mower in reply to pconnie.ks., 06-19-2013 12:28:34
That might be the answer, are those short chains and brackets strong enough ?. everything i've read said to have the front of the mower a little lower when it's mowing and that's the way it's set now. if I shorten that top chain won't it be even more tilted forward when it's down ? there is a little slack in that chain when it's all the way down. there are only 2 positions for that skate wheel (well 3 really ) at the back of the mower and the lowest might be too low for the terrain so the whole thing might need to come up a bit.
This post was edited by Glenn D at 12:47:52 06/19/13.
06-20-2013 05:51:56
 Re: Back to the 2N and mower in reply to Glenn D, 06-19-2013 12:46:57
i have been using this set up for 30 yrs. the holes are a little elongated but many years left in them...phil
Glenn D
06-20-2013 04:52:40
Thanks folks. it works good now.
I have an exhaust question this 2N has a broken clamp right at the manifold. that seems easy to replace unless it's something special. But the 9N has a tiny pin hole just above where the same clamp is (sounds like a steam engine). should I just braze that up? is this a common place for them to go ?
This post was edited by Glenn D at 05:01:48 06/20/13.
06-21-2013 11:03:11
 Re: Back to the 2N and mower in reply to Glenn D, 06-20-2013 04:52:40
Glenn, what did you change? In your top pic I see a couple of things that some mentioned already, the lift pins on the mower are higher than I would expect and the top chain should be tighter so the back of the mower lifts higher. I don't use chains on my 5' KK, it runs slightly down hill in front when lowered and the back is slightly up when fully raised. My lift arms on the tractor are angled down more than I see on yours (lower at the mower attachment point, higher at the tractor) There's something about the angles there that aren't kosher. But as long as it works for you! Have fun with it and be safe.
Glenn D
06-21-2013 11:20:46
 Re: Back to the 2N and mower in reply to W_B, 06-21-2013 11:03:11
I actually didn't change anything from the above set up. I jury rigged a stop for the lift so it wouldn't go too high and jam with the drive line. a few bits and pieces later I'll have a more permanent set up. and it will top out before the shaft hits the mower.
My arms do go almost all thew way to the ground. As Soundguy pointed out the attaching points are pretty high on the mower. I guess it could go on tractors with larger wheels.
06-21-2013 18:15:40
 Re: Back to the 2N and mower in reply to Glenn D, 06-21-2013 11:20:46
I'm guessing it's just an illusion but in all your pictures, your back tires look under inflated.
06-20-2013 11:52:33
the clamp has a top and sure you have it positioned correctly..if you can get to hole easely braze it..the hole will probably be tapered ..lay some brass bout the size of a quarter..hth ..phil
