I expected this actually. When I got this unit the mower was tilted back because the top link was way too long, as a result the drive shaft would prevent the mower from traveling all the way up on the lift and it wore through the boots. the new top link and adjustment of the chain to the rear of the mower brings the thing up perfectly level. the limiter chains work well to maintain the minimum height too.
But now with the ORC installed the shaft is at too great an angle (I still have to cut the shaft) hen the lift is all the way up. is there a way to limit the upward travel? I kind of torn on this because I'd rather not have the blades spinning when it's up which means disconnecting the shaft anyway so it wouldn't matter in that case, but I can see where there might be instances where I need to lift the mower when it's working.
Sorry for all the questions but it'll only get worse as I have another half dozen implements coming I don't know how to use
sorry for the quality of the pics.
