Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8n coil not making contact front mt.
Dell (WA)
06-17-2013 20:20:13
Cal........yer latest report of boggin'n'stallin' now is time consistent with CLOGGED in-the-tank feed. It aint'chur squarecan coil. That is about 1-hr go-bad time frame. Also consider cracking yer gastank cap 'cuz you could be developing a tank VACUUM that prevents yer gravity feed from feeding. .......Dell
06-18-2013 11:53:06
 Re: 8n coil not making contact front mt. in reply to Dell (WA), 06-17-2013 20:20:13
Hi Dell, took a short cut. Unhooked the fuel line going to the carb. There was slow stream of fuel coming out. It would turn to drops by the time it went near the ground. Anyway, took the air compressor and blew 40-50lbs air into it. The gas tank was sure bubbling. Then the stream from the carb line increased 4 fold. Hooked it back up and mowed under load for an hour. Ran great, no problems. I know it may be temporary but I'm smiling. Thanks, Cal
