Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8n coil not making contact front mt.
skyler
06-17-2013 11:58:10
Well I have done everything you said. Last night I had it running very rough w/no rpm. I have played with the wires on the dash as I have added a new resistor block yesterday. Now, no spark at all. 12.8vt at coil top wire. I have reset the new points to 15. Tried no ballast resistor, no luck. I put the old coil back on, still no spark. I am using this diagram for my dash wiring. I changed the key switch terminals a couple days ago as it seems yellow should be on top. May be a problem as I changed other wiring this morning. I probably need to look at the points again, Cal
Thanks to whoever uploaded this diagram. Maybe another diagram would help. There are many on the web with different setups.
