TractorLinks.com
Order Ford 9N Parts Online
Re: Ford 9N fouling out plugs
Troubled 9N
06-17-2013 10:31:27
To be honest it is my father-in-laws tractor and he told me it is not smoking and the plugs are covered in a black soot like substance so I am assuming oil. The carb that is on the tractor is a newer carb (less than 5 years old) I am not sure if he adjusted any of the mixture screws on the carb.
soundguy
06-17-2013 11:01:03
 Re: Ford 9N fouling out plugs in reply to Troubled 9N, 06-17-2013 10:31:27
you may be assuming wrong.
black soot is fuel / rich.
oily black is oil fouling.
you are rich and or may have weak sparks.. which was why it may hav ebeen set rich.
air cleaner may be blocked and choking it too.. and / or choke partially engaged.
post back
Torubled 9N
06-17-2013 11:37:06
 Re: Ford 9N fouling out plugs in reply to soundguy, 06-17-2013 11:01:03
I will defintely look at the air cleaner to make sure that is not plugged at all. Thanks for the great advice
old
06-17-2013 10:42:59
Black sot as in not oily looking or feel to them?? If yes then the carb maybe running to rich or the air cleaner need to be serviced. If oily then it is fouled by oil not gas but black and dry an sooty then gas fouled
Troubled 9N
06-17-2013 10:50:13
 Re: Ford 9N fouling out plugs in reply to old, 06-17-2013 10:42:59
Based on what he was telling me yesterday, I believe it is gas becuase it sounds like they are dry and not oily. Sounds like they are full of carbon hen he pulls them out.
36 coupe
06-20-2013 03:02:00
 Re: Ford 9N fouling out plugs in reply to Troubled 9N, 06-17-2013 10:50:13
Ill try again.when I bought my 640 it had a new set of Champion H10s in it.I drove it 12 miles home,ran fine.It use it was fouling plug a lot.I put in H12s and the problem was gone.I did find that prolonged idling can foul the H12s so bad that you cant move in first gear.I had to bring the rpms up slowly until the fouling cleared up.Ive tested gas fouled plugs in the shop with a Model T coil.The spark runs up the nose of the insulator in thin streams.It CANT jump the gap.The fouling keeps the spark voltage low so you think you have weak spark as the problem.Most favor the Autolite 437 plugs.The Autolite 216 has the same heat range as the Champion H10.This has been posted many times but seems to be ignored .You have to use a HOTTER plug with unleaded gas.
troubled 9N
06-20-2013 04:38:44
 Re: Ford 9N fouling out plugs in reply to 36 coupe, 06-20-2013 03:02:00
Thanks for the tip on the hotter plugs. I think along with the carburator, which seems to be running rich, we should be able to take care of this problem. Thanks again!
