TractorLinks.com
Order Ford 9N Parts Online
Re: 9n ignition
Glenn D
06-17-2013 06:37:16
Yes I thought since another post thread here said to keep it around 3.5a or lower then it would be safe so I left it like that.... it was starting ok just not running for long or tach-ing up. if I took one of them out. (I'll check the OE one, it's still under the dash but looks pretty bad and the one on the 2N was broken in half so I can't use that one) will it be ok at 4.4a ?
soundguy
06-17-2013 06:50:28
 Re: 9n ignition in reply to Glenn D, 06-17-2013 06:37:16
if it will 'start' like it is.. don't mess with it. starting will be the hardest part.. once started.. it should run fine.
again. if good spark on a cold start. go with it.
Glenn D
06-19-2013 06:32:39
 Re: 9n ignition in reply to soundguy, 06-17-2013 06:50:28
Welp turned out to be the breaker plate in the distributor is bad. it had some rust on it and the screw where the spring on the bottom of the coil broke out of the breaker plate. It was pretty clean by then I guess the PO cleaned it somehow but what was left was just too weak.
So the new breaker plates come with the nose bushing so while I'm there should I get the shaft and weights too? the shaft seems ok but the weights are pretty dirty and don't spring back like they should.
soundguy
06-19-2013 06:48:13
 Re: 9n ignition in reply to Glenn D, 06-19-2013 06:32:39
see if they will clean up and move freely. no need to spend money if you don't have to. if they turn out to be bad. of course replace them.. etc.
Glenn D
06-19-2013 08:10:27
 Re: 9n ignition in reply to soundguy, 06-19-2013 06:48:13
They freed up nicely, thanks.
soundguy
06-19-2013 10:04:28
 Re: 9n ignition in reply to Glenn D, 06-19-2013 08:10:27
cool.. saved ya some coffee money!
