TractorLinks.com
Show Parts for Model:
Re: 1 more chargeing ?
L.B,
06-16-2013 21:34:11
So if it is 0, does it mean it is charging? If battery is low does it move to + and - if not charging? or does the v-reg meter the electricity to the sys and keeps the battery,plugs and lights from draining the battery? Maybe I will just put a temp gauge in instead of a amp gauge I understand it and it would be more useful to me as it would be obvious the elec sys was not working when the lights went out.s/m side mount
36 coupe
06-28-2013 05:15:14
 Re: 1 more chargeing ? in reply to L.B,, 06-16-2013 21:34:11
Buying a meter is not enough, you have to know how to use it.
greywolf224
06-28-2013 09:43:38
 Re: 1 more chargeing ? in reply to 36 coupe, 06-28-2013 05:15:14
True If you don't connect the meter correctly you can and will fry it.
For DC (Direct Current) what our tractors are.
In very simple terms, Volts can be measured while connecting the meter in parallel to the circuit being measured and you don't need to break the circuit to measure it.
Amps usually require the meter to be placed in series with the circuit being measured. So you need to remove a wire and place the meter in place of the wire. Kinda like having the current flow through the meter.
AC (Alternating current) whole different animal and its what you plug your battery charger into.
soundguy
06-17-2013 05:45:50
you need to set down and read the book about your meter and how to take measurements.
jmor said if you take your VOm and read across an ammeter it should read about 0 . as jmor said. the ammeter is a shunt voltmeter.
to use your vom.. take a reading from battery hot to ground. see what she makes when off and when running at high idle.
