Two piece old style valve guides - 9n ford
Replace them with the solid guide with the correct valve for a solid guide and spring for you application... 9N's use a longer spring than the standard one use on 8N's....
IIRC, these will work. If I'm wrong, I'm sure Zane and Hobo will correct me.
They DO state: "Also fits 1941-42 4 cylinder 40 HP Commercial Truck (8 pair required)." That would be the truck version of the "N" engine, right?
Split valve guide source
I see Dennis Carpenter has 'em, as well, and for less $$$.
