Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Overheating
Bruce (VA)
06-16-2013 16:08:33
Check out tips 24, 25 & 35.
stoygop
06-16-2013 16:36:17
 Re: 8N Overheating in reply to Bruce (VA), 06-16-2013 16:08:33
24. Doesn't seem to be overfilled. Loose fan belt might be the cause, but I don't know how to tension it further. The fan I have sucks in air, and doesn't blow it out from the engine side. Should I get a different fan? I don't see any way to install the one I have such that it would reverse air flow.
25. Thermostat seems to be installed correctly to my knowledge. Pointy side toward the radiator. I tested it on the stove before I installed it. It opened between 180 and 190.
35. It is there.
Thanks,
Matthew
Bruce (VA)
06-16-2013 16:42:13
 Re: 8N Overheating in reply to stoygop, 06-16-2013 16:36:17
" I don't know how to tension it further. "
Get a shorter belt.
You need 1/2" flex at the midpoint on the belt; no more, no less.
stoygop
06-16-2013 16:57:53
 Re: 8N Overheating in reply to Bruce (VA), 06-16-2013 16:42:13
Do you know a good place that I can buy belts of odd sizes? I have the 44 1/8" belt so I was thinking of getting four or five different belts in quarter inch increments to see what will fit best.
Thanks,
Matthew
Bruce (VA)
06-16-2013 17:49:08
 Re: 8N Overheating in reply to stoygop, 06-16-2013 16:57:53
Loosen the tension adjustment & push the alternator all the way in. Then pull it out about 1". Get the wife's fabric measuring tape & measure it. Or use a piece of string. Take the old belt to NAPA, Advance, etc & tell them you want one of that diameter in X inches.
stoygop
06-16-2013 16:47:05
Simple answer to a stupid statement.
Thanks
