Hi Folks
2N 6v generator needs to go in for rebuild but before I break anything I wanted to know how it comes off? there is a bracket on top bolted to the generator and that has a bolt that goes through a spring to the bracket on the cylinder head. this looks like it's threaded into a castle nut with a cotter pin through it. if I pull that pin will the bolt unscrew? leaving the nut attached to the bracket? the blow up diagram doesn't show it clearly enough for me and all the parts are pretty dry and cranky so I don;t want to force anything the wrong way.
Thanks
Thanks
