Order Ford 8N Parts Online
Re: putting corn oil in my 8n tractor.
Richard Denkha
06-05-2013 18:07:29
are you sure ATF will work for the fuel system?
06-06-2013 07:22:38
 Re: putting corn oil in my 8n tractor. in reply to Richard Denkha, 06-05-2013 18:07:29
The fuel system on an 8n Ford consists of the fuel tank, sediment bowl, and the carburetor. There is NOTHING in that system that even NEEDS lubricating. A little ATF in the gasoline MIGHT give a little extra protection the valve guides and stems, but if you're already using a good grade of motor oil, and change that oil when required, NO additional lubrication is needed.
Too much oil mixed in the gasoline will also have a tendency to foul the spark plugs, and that oil will also reduce the amount of actual gasoline going into the engine, which WILL reduce power and performance.
