Loader Pump manufacturer
Tom Veenker
New User
Hi Guys: Looking for some help. I have an 8N with a Freeman FEL on it. The pump has stopped working - I think I stripped out the splines in my drive pulley at the engine. I have ordered the parts (shaft and hub) from YT. I also want to rebuild by hydraulic pump, but I can't seem to find any Mfr. name on it? All I can find is numbers.
I found 43672 and this sequence:
669 P2 95 604D (I think?)
Anybody know who made this pump? It's 5" long and has horizontal hose ports. I have to believe that this was a very common gear pump that was used for loaders "back then". Any help would be appreciated.
It looks very similasr to this one (Prince) - but the mount bracket prevents me from seeing that location:
http://www.ebay.com/itm/Prince-Manufacturing-Hydraulic-Gear-Pump-SP20B11A9H2R-Keyed-Shaft-677cid-11cc-/171029791232?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item27d22b8200#ht_468wt_877
(quoted from post at 13:59:14 06/05/13) Hi Guys: Looking for some help. I have an 8N with a Freeman FEL on it. The pump has stopped working - I think I stripped out the splines in my drive pulley at the engine. I have ordered the parts (shaft and hub) from YT. I also want to rebuild by hydraulic pump, but I can't seem to find any Mfr. name on it? All I can find is numbers.
Replace the pump with a new one. A new generic gear pump is $100 and will work just fine as long as you match the rotation and size.
Many of those pumps are not rebuild-able and if they are the kit cost as much or more then a new pump will cost. Found that out many years ago and found that the kit was $50 then a new pump
Thanks Guys - I think you're right. From what I have found, it IS better to go with a new pump.
I think that is what I WILL do.
