861 powermaster wheel removal
Tidioute
New User
I need to remove a front rim from a 861 power master. I removed all the lugs but I am not sure how to remove the center piece that seems to be holding the rim on.
Can some one guide me through the removal.
Thanks
The rim is rusted to the hub around the center, I have ran into that many times. Once you remove the lugs it should come off. If you can drive the tractor put the lug nuts back on but leave them loose and make a few turns and try to pop the rim loose. If you can't drive the tractor you will have to take a block of wood and a BFH and carefully try to pop it loose from the hub. My 2cents worth Greg NE
Do as Greg says or hit the back side of the rim with a hammer. If you do the drive around thing do not have the lugs very loose or you will be buying new lugs and maybe a new hub due to breaking the lug bolts. Had the same problem on a Farmall cub yesterday and a whack with a hammer had them off
Loosen the lug nuts and then take about a 6' chunk of 4X4 and slug it a couple of times. The wood wont hurt either the rim or the tire and will knock it off.
rim's either rusted to the rim.. or it's paint-glued on.
do as the others said.
baord and hammer.. or drive with the lugs a tad loose for a figure 8.
