Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Right Wheel Noise
Dell (WA)
06-05-2013 07:35:21
BDodge........you ask......"when it has been running for a while, the tractor will quit. Wait 30, it will start and then quit again. Any solutions?".......
There are 4-common runtime issues with the weird 4-nipple frontmount 9N engine.
1) runs fer about 1-min and quits; restarts innna'bout 5-mins; BAD condenser; NOT yer problem
2) runs fer about 5-mins and quits; restarts innna'bout 5-mins; CLOGGED in tank fuel filter; NOT yer problem
4) runs fer about 1-hr and quits; restarts innn'about 4-hrs or overnite cooldown; BAD squarecan ignition coil; NOT yer problem as described, but could be depending about yer definition of "runs fer a while"
3) runs fer about 15-mins and quits; restarts innna'bout 30-mins; BAD weaksister ignition switch ($15, cheap) Most likely yer problem ........Dell, yer self-appointed sparkie-meister
B.Dodge
06-05-2013 08:56:13
 Re: Right Wheel Noise in reply to Dell (WA), 06-05-2013 07:35:21
It will run for an hour then sound like it is running out of gas, power down and quit. I wait 30 minutes, it starts then after 10 minutes it will power down and quit. Fuel flow good and spark is good. I never had this issue before. It makes like it wants to run when I start it but it will not go.
Dell (WA)
06-05-2013 10:35:35
 Re: Right Wheel Noise in reply to B.Dodge, 06-05-2013 08:56:13
B.Dodge........what does my item (4) say??? 1-hr run time. BAD squarecan ignition coil???
Once the internal insulative tar melts, it will ALWAYS melt and cause weak sparkies, just as you are complaining. Unfortunately, the squarecan ignition is NOT very robust.
Remember, ittza 2-bolt, 15-min job to replace/adjust the points (0.015") on the kitchen table. Just un-snapple yer capple and letter dangle and walk. Installation is a reversal of the removal ...except... finger start the 2-bolts. Install the rotor and rotate until the OFFSET tang drive fits the OFFSET camshaft slot. Now tighten the 2-bolts and re-snapple yer capple. Simple, eh?
Remember to "polish" the INVISIBLE corrosion from between the points (0.015") after installation. Me? I clamp a clean $1-bill between the points and pull. Iff'n yer really cheap, tear a strip from HEAVY brown paper grocery sack and use that. ........HTH, Dell, yer self-appointed sparkie-meister
Richard Denkha
06-05-2013 12:37:56
 Re: Right Wheel Noise in reply to Dell (WA), 06-05-2013 10:35:35
Hi their, can you please tell me what are specs to set my points and condenser on my 1951 ford 8n tractor? thank you.
JCinKY
06-05-2013 13:24:17
 Re: Right Wheel Noise in reply to Richard Denkha, 06-05-2013 12:37:56
51 would make it a side mount.
If thats correct, points gap at .025.
Nothing to do with a condenser but install it.
B.Dodge
06-05-2013 11:06:03
Thank you. I now have information to work with. That's why I love this forum. I have gained so much knowledge in the last year on my tractor. Will let you all know the results.
