TractorLinks.com
Order Ford 8N Parts Online
Re: Working on 8N Tomorrow
soundguy
06-05-2013 06:42:30
but it will run.. :) ( if that was the issue.. )
JCinKY
06-05-2013 07:19:39
 Re: Working on 8N Tomorrow in reply to soundguy, 06-05-2013 06:42:30
Yes sir. I think he's got a few acres that he needs to bush hog.
One thing I can't forget while at work, is to print JMORs wiring diagrams. I've only done 2 12v conversions and all my stuff is still 6v.
soundguy
06-05-2013 11:36:08
 Re: Working on 8N Tomorrow in reply to JCinKY, 06-05-2013 07:19:39
12v is pretty easy.
in general.. most o fthe N wireing stays put.. and you can retask a few wires that were for the vreg and genny.
for instance.
ignition and headlamp and starter wiring remains unchanged * ( add 12v lamps.. and add correct coil, and if need be, resistor inline. )
for the alt to genny swap.
line going to armature goes to charge stud. at reg. connect bat and arm wires and remove reg.
run the field wire to the #1 on the alt on one side.. and on the other side.. run it to a 194 lamp then to the key switch.
jump #2 to charge stud.
that's pretty much it...
