TractorLinks.com
Show Parts for Model:
Re: Right Wheel Noise
soundguy
06-05-2013 06:34:47
at the moment it quits, check to see if you have spark at the plugs. if you have good spark, then pull the drain on the carb fuel bowl. should be able to get a steady stream of fuel. if not.. check for tank vacume.. and stuck float..e tc. you can rap a screwdriver handle onthe side of the carb and see if it make sit flow.
ont he popping sound, is it brake dependent? does it go away if you press the brake? how about if you pull the pedal up?
any oil leakage from that axle seal?
have you checked all lugnuts and rim to center bolts/nuts?
i'm not as familiar with that early hub and axle design.. but if none of hte other panned out..i'd be be checking the bearings.
jack her up and se eif there is considerable play. might be bearing pop.
post back.
B.Dodge
06-05-2013 06:45:09
 Re: Right Wheel Noise in reply to soundguy, 06-05-2013 06:34:47
Noticed the oiler filter was low, could be sediment in carb. I know I have fuel flow. Sometimes I forget to turn key on, try to start, and the carb overflows. Then when I turn key on, it starts, runs, then just quits.
The clunking noise is once a rotation. Yes, I have leakage. All nuts are secure for wheel.
soundguy
06-05-2013 06:49:40
 Re: Right Wheel Noise in reply to B.Dodge, 06-05-2013 06:45:09
i'd jack tht side up and see if you can feel any bearing play.
