Before I order parts.....
oldtanker
49 8N. With the draft/position lever in the up position the 3 point lifts. In the down position it will not move. I know the piston is leaking, what else should I be looking at?
Thanks,
Rick
(quoted from post at 20:11:45 05/13/13) 49 8N. With the draft/position lever in the up position the 3 point lifts. In the down position it will not move. I know the piston is leaking, what else should I be looking at?
Thanks,
Rick
ome possibilities: adjustment, worn draft control plunger seat, bent draft control link,
Sound I know I should it's just that I'm using it and hate to have it apart till parts get here.
Rick
