Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Position Control
ZANE
05-13-2013 20:03:56
8N FORD TRACTOR LIFT ADJUSTING JIG AND BOOKLET FOR ADJUSTMENT
This is something that has been needed for years. It is not an original idea for me. I used to be a mechanic and parts man in a small dealership in Talladega AL. and used such a jig to adjust the 8N lifts. The jig that was supplied to every Ford dealership was cast aluminum and I suppose that most or all of them have been lost or broken over the years because nobody can lay hands on one. I just made up my mind to resurrect the knowledge and so the booklet that I have compiled and the jig I have fabricated by actually repairing and adjusting an 8N lift and fitting the jig so it can be done in a more practical way. What the jig does is give a hard fixed point to adjust the linkage to.
I am going to charge a total of $65.00for the pamphlet with illustrations and text instructions for adjusting the lift along with the jig and a new cam follower pin. This price includes the shipping in the USA. If sold outside the US the shipping is more and I will state it for the destination. Usually about $10.00 more to other countries, but more in some.
Adjustment alone will not fix a system that has excessive internal hydraulic oil leakage. If the lift will not hold a load for more than a couple of minutes you should repair the lift while the cover is off for adjustment. Such things as replacing the pressure relief valve and the piston rings on the ram cylinder piston etc.
Total is 65.00
PRICE OUT OF LOWER 48 IS $75.
Send a personal check and it I will ship when it clears the bank
Send a Money order and I will ship the next working day.
I now accept PayPal too. Email wzsherman@aol.com
Send toŚ
Zane Sherman 2824 Renfroe Road
Talladega Al. 35160
256 268 2327
welding man
05-13-2013 20:35:56
 Re: Position Control in reply to ZANE, 05-13-2013 20:03:56
Zane I have an original, if I can be any help. Here is a picture of it and one for the NAA and 600's
ZANE
05-14-2013 18:40:55
 Re: Position Control in reply to welding man, 05-13-2013 20:35:56
That is the first original 8N lift jig I've seen since I quit the dealership in 1967,
Mine is fabricated from steel so it doen's break quit as easy as the aluminum ones did.
That is great!
I never did see the ones for the later models like you have????
We did it with a feeler gauge at the control valve and I fabricate those too with my lift adjusting kits.
Zane
JMOR
05-14-2013 20:11:01
 Re: Position Control in reply to ZANE, 05-14-2013 18:40:55
Quoting Removed, click Modern View to seeHey, Zane.........that factory jig has a hole & two notches in top......why does yours have only one? What other for?
whopist
05-15-2013 03:00:50
 Re: Position Control in reply to JMOR, 05-14-2013 20:11:01
[URL=http://s264.photobucket.com/user/whopist/media/Ford-fixture_zps0a38ccb1.png.html][/URL]
This post was edited by whopist at 03:02:38 05/15/13 2 times.
JMOR
05-15-2013 05:26:33
 Re: Position Control in reply to whopist, 05-15-2013 03:00:50
Quoting Removed, click Modern View to seeGood find! Thanks. We should all be as observant.
mbramble
05-15-2013 04:26:22
Any chance of you posting steps 1-10 also?? :)
whopist
05-15-2013 07:07:52
 Re: Position Control in reply to mbramble, 05-15-2013 04:26:22
[URL=http://s264.photobucket.com/user/whopist/media/Ford-fixture1_zps7cb81eef.png.html][/URL]
[URL=http://s264.photobucket.com/user/whopist/media/Ford-fixture2_zps042dd0a9.png.html][/URL]
[URL=http://s264.photobucket.com/user/whopist/media/Ford-fixture_zps0a38ccb1.png.html][/URL]♦
mbramble
05-15-2013 10:01:11
 Re: Position Control in reply to whopist, 05-15-2013 07:07:52
Thanks!!!!
