Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: mouse in the air cleaner
bruce werner
05-13-2013 18:17:37
The screen is mounted on the outside of the hood, then a metal cover goes on that has louvres on it to let air in. On the inside of the hood, there is a little space between the sheet metal of the hood and the side of the air cleaner canister, they have to be crawling in there. I'll get a big hose clamp and clamp some fine mesh screen over that intake hole. If something is missing from the tractor I'm unaware, nothing there right now to stop a mouse.
soundguy
05-14-2013 06:33:00
 Re: mouse in the air cleaner in reply to bruce werner, 05-13-2013 18:17:37
the fittment is probably a lil sloppy. you are also likely missing the heavy hair filter.
bruce werner
05-14-2013 17:03:06
 Re: mouse in the air cleaner in reply to soundguy, 05-14-2013 06:33:00
The brillo-pad type filter is in place inside the filter canister, all full of mouse nest litter, got a new one coming. I can see that the baffle flange does not extend over far enough to fill in the gap going into the air hole in side of filter. Will jury rig something there to fix it, thanks all. I have 4 cats, but not around the shed where this happens
soundguy
05-14-2013 17:41:44
 Re: mouse in the air cleaner in reply to bruce werner, 05-14-2013 17:03:06
the hair filter is not the metalic mesh in the air canister. it's a seperate 'pad'
bruce werner
05-19-2013 16:35:00
 Re: mouse in the air cleaner in reply to soundguy, 05-14-2013 17:41:44
All fixed up now. New air funnel part is longer than one I had. It reaches on over to ho;in canister. I have the hair like steel up inside the housing too, just replaced the brillo like hair pad on the bottom. New oil, and ready to go.
soundguy
05-20-2013 06:20:46
 Re: mouse in the air cleaner in reply to bruce werner, 05-19-2013 16:35:00
glad it's fixed.
neithe rof the pads i referred to are metalinc.
but no problem.
soundguy
