TractorLinks.com
Show Parts for Model:
Re: Engine tapping on startup
Charner
05-12-2013 17:37:33
Try other test that are recommended. Then, you could have sleeve no. one slipping when cranked and engine cold. when heats up it snugs up a little and less noise. You can check this by removing spark plug in no. one and crank. Does the sound get louder. If so, coulb be you problem. You can pull you head and do on sight examination for the cost of a head gasket and about an hour. Check valves while in there. Good luck.
DScott
05-15-2013 08:03:16
 Re: Engine tapping on startup in reply to Charner, 05-12-2013 17:37:33
Yep, I had that issue on my 49 8N that probably didn't have 20 hours on a overhaul when I first heard it. The tractor ran great, had good oil pressure and the valves were properly adjusted (I suspected the valves at first). But it had a light knock or pecking that would get better and then wors. Also, the sound seemed to change as the engine warmed up but it never went away. I pulled the head, turned the engine over and the #3 sleeve popped up. Cleaned up the cylinder and sleeve, applied sleeve retainer and that solved the problem.
