TractorLinks.com
Show Parts for Model:
Re: leaking hydraulics from bottom of transmission
MIKE HARMON
05-12-2013 06:18:25
It will not hold the 3 point for more than a minute or two. I have not looked at the pump through the window yet, but it started to lose its hold shortly after I tried lifting an out building that was heavier than the tractor.
I'm guessing now that I blew a gasket and its leaking.
soundguy
05-12-2013 14:35:57
 Re: leaking hydraulics from bottom of transmission in reply to MIKE HARMON, 05-12-2013 06:18:25
at this point you need to stop, and get a service manual.
while it MIGHT need work on the pump ( relief, etc.. ).. many, many 'won't hold' problems are from a leaky piston/oring/ring issue ( however there are others. like lekay gaskets and pinholded pressure tubes..e tc.
pays to do some observation and troubleshooting before jumping to the comclusin you need to pull a part off that may not be contributing to the problem at all.
TOM N MS
05-12-2013 14:09:40
Very likely u will see the proplem with oil streaming from the top area and that will be good news--very likely not the pump itself.
