Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: leaking hydraulics from bottom of transmission
MIKE HARMON
05-11-2013 18:59:00
OK, I just looked at the exploded views and no mine does not have a cotter pin in it.
I did fill the housing with 5 gals. The bolt suggestion is great . Thanks.
By the way, any trick to getting the rear tire off? I have the 6 bolt rim. Just got a nasty flat today by way of fencing wire through the side wall. But I'll be dipped if I can get that rim busted off.
Dell (WA)
05-11-2013 21:06:11
 Re: leaking hydraulics from bottom of transmission in reply to MIKE HARMON, 05-11-2013 18:59:00
Mike........eazyway to bust yer reartire off, is to remove ALL the 8-axle nuts and then LOOSELY re-nut 2-nuts and then drive in figger-8's. Roundy-round. This will bust yer 8-studs loose. CAUTION: those rear ag-bar tires can weigh up-to 300#. So iff'n it starts to tip-over; guess what??? Gitt outta the way!!! Many ar-bar tires are filled with CaCl (calcium chloride) salt water for added traction weight. .......Dell
Royse
05-11-2013 20:39:59
Leave the rim on.
Let the tractor hold it for you while you change the tire/tube.
If you really want it off, you can take it off at the outside 6 bolts
or the inner 8 lug nuts.
Either one works, but the inner 8 makes it easier to put back on to me.
